I've talked with Briggs and it's fine if you join both wires before the diode. Then you get extra juice to charge your battery and power electronics. Just a thought
Yea, I would think under most circumstances, it shouldn't overload it. I doubt that there's a lot of amperage coming through that AC line that normally powers 2 small lightbulbs. It's got to be less than 1 amp and I would hope Briggs would spec electrical parts with a pinch of wiggle room. Even still, diodes are cheap and if you know how to split and re-join wires properly, you probably know how to replace a diode
I just came back to say THIS IS WRONG. I didn't want to make a new post but I don't see an edit button. Basically, my info and understanding here is wrong and I hope nobody suffered with this poor information. DO NOT CONNECT THE TWO AC WIRES TOGETHER ON THE STATOR.
Storytime:
I have a dual-circuit stator on a 90's vintage Briggs opposed twin. I thought the 2-4 amp DC output wouldn't be enough as I plan to add a water pump, lights and possibly other accessories and while running the engine with these accessories, I would still be draining the battery. The dual-circuit puts out 2-4 amp DC and 5 amp AC. The DC side has a diode which converts the AC. Basically, it has 2 AC outputs. I thought by connecting these together, I would have max amperage with AC output then install the diode and hopefully see 7-9 amp DC to charge the battery and run equipment. I even contacted Briggs support and they said it would be fine.
I fried my stator.
I'm only guessing here, but it's an educated guess from research, the two AC circuits weren't in sync and when I joined them, they fought each other and built up heat and melted my stator. What I should have done, and what I am going to do when my new stator (dual circuit) arrives is use 2 diodes to keep the AC separated and then join on the DC side. I am going to do this with a rectifier that has 2 AC inputs and 1 DC output. I also plan to put a switch on the secondary AC input so I'm not overcharging my battery with 9 amps when I don't have accessories running. It'll basically be a boost.
Hopefully nobody else suffered my fate and hopefully other people are curious about doing this and learn from my mistakes
