Wiring on a 2165 from '96-'98
Sdmcarlson
Hello, new user... Sorry, copying thread I started
I have a 2165 from '96-'98 that I'm trying to repair the wiring on. Pictures of all the connections would be helpful!!!! I have the wiring diagram but my interpretation is in question...lol
Problems in particular, the small red wire from starter - does that go to the red wire junction that is behind the firewall, near solenoid (3-4 red wires are joined together there)? Also, the red wire that goes to the PTO clutch is burned and there is a 2nd red wire that comes out of the connector that isn't represented in the diagram. Is that supposed to be there and if so, where does it go? Finally, the black wire that comes out of the key switch, that is missing - - do I need to add a 20 A fuse and attach that to the battery side of the starter solenoid?
Sorry, this wiring is a mess
