Check the carburetor choke make sure its working properly...!
Choke seems to work fine.
How?
It could also be all of that old bad gas in the tank.
It's not the gas it has the issue with new gas, i think the choke works since when i move it the engine will idle down. It wouldn't do anything if it's not working right?
Does that engine have a primer to push?
No primer. It's not the gas! The same gas is used in a lawn mower, generator, a car zero trouble on any of them. Had the same issue with the power washer last year with different gas. It's always been hard to start. I need to change the oil in it but it does not have a drain plug stupid that i'll have to turn it on it's side to get the oil out. A drain plug can't cost very much.
