Will Fite but not through a plug
woden_88
I loaned my mower to a guy and he brought it back not running so I checked the plug and replaced it 3 time with new ones pulled the cover off cleaned the flywheel and coil of rust put it back together and saw it would fire at the wire if I held it but can someone please tell me why it will not fire threw the plug? Thank you
Either a partially grounded kill wire, or a bad ignition module. Remove the kill wire from the module and see if will fire then. If not replace the igntion module.
chance123
When you check for spark on the plug, is the body of the plug touching a good ground?
