When I can get her outside (mower is currently in my basement) I will see if she runs on gas. I got her at an auction and I don't have a garage to work in so I brought it in my basement for something to tinker on. She has good spark and runs on either but being in my basement I don't want to stink up my house with lawnmower exhaust. Looks like I will wait a couple of weeks and see how she runs when I get her outside. Thanks for your info.Compression gauges are not good on most lawn mower engines.
If you are having a weak running mower, hard to start, etc.. You should be looking at the ignition points.
Points - wrong advise unless the engine is missing on some power strokes. 50 pounds is enough to start and run. Compression varies with speed of rotation. Most small engines have no specs for compression as a basis for such a reading cannot be established. Cleaning the carbon up by taking the head off is fine as long as you remove all that may wedge open a valve and cause a problem you did not have or do not properly re-gasket and torque. A leak down is the only sure way to determine externally if compression is being lost. Turning thee engine over slowly and feeling the resistance is a quick way to assess the likelihood of compression losses. The post on valve seats and rework is relevant if some compression is lost not due to carbon or valve lash settings. If the valve can be turned when it is supposed to be closed, the valve lash is to tight. Any non flat surfaces on the valve or seat and not shinny are sure to be the root cause of any loss of valve lash. Simple carbon under the valve that did not crush can be a cause. A few hammer taps on the valve can crush it to close but still needs to be certain it is sealing and will when assembled. It can be hard to visually see if the valve is hung on carbon as the lift of only .001" can cause some loss of compression. Some carbon issues will disappear when run for awhile. Then we have sticky valves or bent - these tend to be more intermittent and often a trained ear can hear the difference. Now we can add three final valve issues 1) valve seat loose in the block, 2) bent valve, 3) worn valve guide causing wandering seat to valve closures. I am sure if a think awhile, I can come with more such as a burnt valve.Compression gauges are not good on most lawn mower engines.
