That would be the dream. A lot of surrounding yard with my home in the center. Acres of grass surrounding my home.
I'm not much of a fan of trees because all of the leaves and twigs and everything. I have a neighbor with a huge tree that sits maybe 5 feet from the property line. All I ever do is pick up twigs, leaves, and other crap that it drops all over my yard. I wanted to cut all of the branches that hung over my yard, but the neighbor would not allow access to his property for the contractor. So I got the largest A-Frame ladder I could get and I scurried up there two summers ago and used a pole cutter to cut as high as I could.
I cut piles and pile of branches but I could only cut 20-30 feet in the air. It did make an impact but it wasn't significant. There are just less branches hanging low.
All of the debris that the tree sheds gets on my nerves somewhat, because it is a constant year-round clean-up routine. I wish the ash borer bugs would get in there already. They have been causing havoc on hundreds of trees in my town the past two years. Hundreds of trees have been cut down due to the EAB.
