which should i put together
I have a 680530 and another older one both self propel
both run fine but one is missing wheel air filter and cover
mechanic mark
Toss a coin, let us know if it was heads or tails.
Vervepipes
Does one have a significantly better deck?
Flintmotorsports
if it was me I would fix the one that is going to take the least amount of work first then hunt down all the parts
you need for the other unit while fixing the unit that need the least amount of work.
the other is a 1984 R8241
witch would be more easy to do
