So, I have been repairing and refurbishing a lot of LawnBoy mowers, both for my own "collection" (haha) and maybe to sell. Well of course I gave my son a Silver Series 4.5 hp steel deck 10201 rock stock mower to use. It failed on him the other day. It had no compression, piston spun freely. Well, I dis-assembled it, and the piston was scored and so was the cylinder, one ring was stuck, and one crankcase seal had popped out. I cleaned it up, cleaned the piston on my wire wheel on my grinder, made sure the ring-slots were clear, put a new set of rings on it, new crankshaft/crankcase seals, put it all back together and it starts on one pull, and runs strong. Now it has a scored piston and cylinder, but no rough edges. Can these things be killed at all? This has excellent compression. I traded out another exact same mower with my son, and I will give this one a yard test tomorrow, but it sure seems good. Runs smooth, no vibration (I balance blade, always), and the little bit of test cutting I did showed me the engine was strong.
