When a battery is really DEAD
packardv8
I've been cutting with riding mowers for more than fifty years. A battery usually lasts two years, seldom more than three. I keep it on a trickle charger, but sometimes, toward the end of its dying season, like now, it gets weak enough to require a jump start. Today, on the Timecutter SS4235, after a jump start, I began mowing. Halfway through the first round, it began to sputter and die. Disengaging the PTO switch the engine would run fine. I checked the wiring, just to be sure, but the workaround was to put the jump start battery and cables between my legs and power the electrics that way.
First time in all the years, the mower charging system didn't have enough output and/or the battery was so dead, it couldn't handle the amp draw from the PTO with the engine at full throttle.
jack vines
Sounds like your charging system is not working. With engine running, at full speed, and no blade engagement, measure voltage across the battery terminals. It should read more than 13 VDC. Less than that I suspect bad voltage regulator or stator.
NO!! I'd much rather it was just a dead battery.
Actually, thanks for the suggestions. Got to fix what's wrong, even though it cost more.
jack vines
Thanks Ilengine.
So Packard, measure the resistance of the clutch. At 1 ohm, it'll draw over 12 amps, 2 ohms 6 amps, roughly. It depends on the voltage with engine running.
