wheel motor squeeling
Pack Way
Hi, I have a Ferris IS 3000 xtreme with about 1200 hrs on it. The left wheel motor or pump is squealing when under hard load. If I'm mowing across a slope and the left wheel is on the low side where it has to work harder it will squeal and lose power. It is slowly getting worse and Pump and Motor are very expensive. Does anyone know if it's the wheel or pump making the noise and am I better off replacing both.They are around $800.00 each. Any guidance from anyone with experience with this would be most appreciated.
