virtual_guy
- Mar 22, 2021
- 18
I'm at my wit's end. You all led me in the right direction when we found a scored piston. I changed it and the cylinder. Sealed it back up with Loctite 515 and with a coat of oil on the cylinder wall. Compression checked at about 125-130psi. There's a good blue spark and the spark plug is wet.
Won't fire.
The air filter is new. I checked the spark arrester and it was clean, tried to start with the spark arrester off.
Still won't fire.
I checked that the alignment pin on the flywheel is intact and the flywheel is seated on it correctly.
What can I check next other than the direction to a dumpster? Surely I'm close to getting this POS running
Won't fire.
Still won't fire.
