I saw on here where someone recommended something that would help trace where an oil leak was coming from. If you see this post would you be kind enough to share the information with me. I have a Kohler CV 22 65594 that is leaking somewhere on the side opposite the starter right at the top of the crank case where the baffle bolts to the crank case. It only leaks when the engine is hot. So I'm thinking it is a porosity in the cc that opens up when hot. By the time I can get to it to find where it is coming from I can't tell where it is leaking. Any help would be appreciated. Thanks in advance.
