figuring8out
Hello, I'm currently working on a Troy-Bilt 21" XP self-propelled mower 175cc, model 12AI869F011 as it stopped propelling recently. Assuming the problem is a worn drive belt, I bought an after-market one and have it on. The last time we changed the belt was 2018 and as my husband is working out of state, I'm trying to fix it myself, not knowing fully how all of the mechanisms work. Last time we changed the belt, my husband cut a four-inch access hole to the back of the chassis to have access to the belt attachment to the rear transmission. I got a tin can end to fit over the hole and attached short screws to cover it, so it's now easily accessible.
I'm having problem with the plastic lower pulley assembly as to which way it's supposed to go (align with mower). I thought I put it back in the way it was before I disassembled it, but apparently got it wrong as now when I start it and depress the drive bar, it doesn't even hesitate to move like it was doing. I can't find a ytube on this particular type of mower. Do I install it as it is shown in the spec? I assume this is how it should go in, but I didn't reference this spec before I worked on it. Also, why are there two holes for the drive cable spring to attach this part? The cable spring hook fell out when I took it apart and so I'm not sure which hole it should go in.
Thanks for your time and looking in to this. I appreciate it. I like this mower and it has seen some use as we bought it in 2010 for a bit over $400. I like the rear-drive mowers better than the front-drive ones, especially in our rough yard that has hidden rocks the armadillo kicks up, etc.
P.S. Next day, my husband said which hole you use depends on the length of the cable used on different models of mower. That makes sense. He calls the part a wedge cam. That's engineers for you.
