HI new to the form.
Have a 2007 Cub Cadet with blower. Last year I was determinded not to freeze when clearing snow. I designed and built a clover for me. Used PVC from Lowe's and some clear 40 MM vinyl to make a clear cover (like a golf cart cover) for the operator area. The result is a 100% view when clearing, no snow on me, and some engine heat to the operator area. The project cost $127.50. The vinyl is held to the PVC with vlecro tape. It is attached at four points on the frame with pipe hangers used for plumbing.
In addition the scraper blade on the blower was replaced with a tire! cut the side walls off a tire then cut across the tread. That was a very hard job. Layed the tire flat tread down and bolted the tire to the bottom of the blower. Took some work to get the position correct. Now the blower scraper i a tire tread and walks over the uneven concrete. Scraper blad cost $125.00 Used tire $5.00 with elbow grease.
