mhavanti
- Oct 12, 2014
- 924
HDCowboy42,
Good luck!
Now, do this and you'll be happy before you have an opportunity for all of us to make you feel like you bought a piece of crap. It isn't 100% necessary if you cut your grass dry. If you can't always do that and you let it get really long, it may clump slightly although I never experienced it with Bermuda.
There are a few upgrade modifications you can make, although again, they aren't necessary.
The two things I do recommend are the lowering the enforcement bar and installing the grass catcher scallop block off plate made of (HDPE) High Density Poly Ethylene.
Here is a video on the enforcement bar modification and you'll find the block off plate videos on that channel as well.
Enjoy the mower and good luck,
Max
https://www.youtube.com/watch?v=OUPaa8JoZJ8&t=350s
Good luck!
Max
