Welcome to the Hustler Forum -- Check in Here First!
Hi there. I'm the owner of a lawn maintenance company with two Hustler Super Zs, one with a 60-inch deck, the other a 72. Both are rear discharge decks.
OK, I have 2 mowers, a 7yo Fastrak 48" and a new 2017 Fastrak SD 54". I live "out on the farm". Also have a Kubota MX5200 4WD and numerous other toys. Thinking of downsizing as all this work is cutting into my playtime.
Been very happy with my Hustlers so far.
Hi everyone,
I have a hustler 4420 and having trouble sourcing parts downunder, hoping some of you folks might be able to
point me in the right direction perhaps a dealer who carries parts for older hustlers.
The main parts I`m chasing is the electric clutch and steering shock absorbers.
My machine has done 3150 hours fitted with a 72" rear discharge front and cabin.
thanks in advance
Paul
Paul,
I don't have any idea what part of "down unda" you're located. However, if you find bertsmobile here in the forum, I'm going to bet he can help you out and may just have a clutch in stock that can be fit to your old Hustler. Also, bert is Tha Man here in the forum. If he says it, put your money on bert.
I'll also see if I can find you a source.
Welcome to the forum and good luck,
Max
Paul,
What is the serial number of your Hustler and is your unit called a Quadracycler?
Here is the manual support page for Hustler and you should be able to get the manuals for your mower. Parts as well as maintenance manuals.
Again, good luck, Sir.
Max
