- Nov 29, 2014
- Threads
- 64
- 24,727
If you are going to work on blue smokers you will have to set yourself up with some compression pumps & vacuum gauges.
Otherwise you ar urinating towards the wind, some time all goes fine the ret of the time you will have wet trousers.
Go to Walbro and down load the full service manual.
It has every thing you need to know about diaphram carbs there, some really good videos all dome in plain easy to understand english.
All "cube carbs" work th same & the diagnosis & repair proceedures ar the same regardless of who mkes the carb.
Go to "Ereplacemnt parts" on their web site is a good general proceedure for diagnosing blue smokes.
Never assume anything, start at the beginning & go through to the end.
They oft have more the 1 problem and it is a waste of time working on a carb for an hour only to find the crank seals have gone.
You replace the seals and fine the primary compression is poor and finally pull off the exhaust to find the piston looks like a railroad track.
So by now you have spent $ 30 on parts, put in 3 hours of work on an engine that will not go so have to give it back to the customer as unrepairable and wear the losses which won't send you broke but ain't going to buy you any beer either.
I have a vacuum cleaner that blows as well as sucks so after I do a carb I hook the carb to the vacuum and check that fuel is comming out of the engine end.
I am working on a flow bench so I can bolt the carb to it and check things a bit better than tying to do a 3 hand shuffle and it is hard to hold the hose against the carb when the choke is closed but the low speed jets are the ones that block up most.
This is a lot lot lot easier than bolting it back up to the engine and pulling the cord till your fingers turn blue.
