Warning Signal
ROY44
I have a 2003 commercial grade Bad Boy Model 6000. I purchased it used and do not have the manual for it. The online manual for Bad Boy mowers does not address this. After 2 hours of continuous cutting with all fluid levels normal, the mower emits a shrill siren type of sound as a warning for something. What would the warning be signaling?
I have no idea what a Bad Boy is, but if it's overheat that's a great warning. Nothing worse than overheating aluminum , or steel, for that matter. Surely someone will help you with this on the forum.:anyone:
I would guess over heating as the above poster. Or a short somewhere?
