Walker Mower 25HP Kohle
Model and spec number would be helpful.
First what is the fault code?
Fault codes are access as follows:
as blinks or fl ashes of MIL. Access codes as follows:
1. Check that battery voltage is above 11 volts.
2. Start with key switch OFF.
3. Turn key switch to ON and OFF, then ON and OFF,
then ON, leaving it on in third sequence. Do not start
engine. Time between sequences must be less than
2.5 seconds.
4. MIL will blink a series of times. Number of times MIL
blinks represents a number in blink code.
5. A sequence of four digits make up a fault code.
There is a one (1) second pause between blinks of a
fault code. There is a three (3) second pause
between separate fault codes. After fault code(s) are
blinked a two digit 61 is blinked to indicate program
has completed.
a. It’s a good idea to write down codes as they
appear, as they may not be in numerical
sequence.
b. Code 61 will always be last code displayed,
indicating end of code transmission. If code 61
appears immediately, no other fault codes are
present.
Note: System may just need to be reset.
