gregjo1948
If you put 10hp on a full grown Ferris Z, it would have trouble turning the blades without mowing grass. These machines spin their blades extremely fast, travel over 10mph while mowing uphill, and weigh upwards of 3/4 of a ton. 10hp will work OK on a YT/GT with a 42" deck weighing 300lbs. mowing at 4mph but it'll take all day to mow a lawn that a 61" Ferris will do in 2 hours. Until you operate a Ferris with the totally independent suspension and mow, what used to be hay fields/pastures, you can't imagine how much better it rides than a YT/GT. YT/GT machines are good enough for a small city lawn and are handy to pull around a little yard cart but if you want to get large or many lawns mowed, a Z with bigger hp is the way to go. 10 hp engines won't work worth a hoot and won't last on a Z. That's why the manufacturers install the big hp twins, triples, and even diesel engines. Sorry about my rant but, 10 hp on a Z just struck me wrong!!!!
