I took the head off of a 5hp Honda to free up a stuck valve. Valve adjustment is .0015 to .0020. This seems pretty loose to me. Is this correct. Thanks
And double check the specs as Honda generally use mm for valve lash not inches.
Thanks bertsmobile1: I will do that. Hope all is well in Australia.
My 5.5 HP is 0.15 mm and 0.20 mm respectively.
