I've used MMO for years without any issues in both 2 strokes and 4 strokes. Don't add more than recommended and you'll be fine. I like MMO better than Seafoam as a fuel system cleaner. I've checked the plugs after a couple months of mowing, and they have been burning just fine. It helps keep the piston and valves cleaner too...
L8R,
Matt
Maybe so. But I don't mind going the extra step to keep my engines in top running condition. I'm very OCD about maintenance. I change the oil twice a summer and use nothing but synthetic oil. I take care of my lawnmowers the same way I take care of my cars. Plus the cleaner the piston, valves, and fuel system are, the more efficient the engine runs. That's why my 22 year old Craftsman II push mower still fires up on the first pull and doesn't burn any oil. That little 3.5 Tecumseh still runs like the day it was bought...
L8R,
Matt
Yes are a few of you out there. 99% of the mower owners put oil and gas in them and run them. My John Deere 68 is older then your Craftsman and it just runs just fine. Keep up the good work and you will get another 22 years out of that Craftsman.
