Using a balancer on a mower blade
mois25
My good neighbor was giving me valuable advice and part of what he said was that it is important to always use a balancer. Is there any danger to the mower in general and if a balancer is not easily accessible can one make any modifications?
I have been clamping mower blades in a vise to sharpen them with files for over 35 years, really, the only "Balancer" you need is a finish nail driven into a wood block. Just hang the blade on the horizontal nail and if the blade is unbalanced the heavy end will be lower. I have NEVER had an unbalanced blade, because by filing you remove so little material from each end the blade usually remains well balanced.
I have been filing my blades for years, not taking to much off . and then more recently (3 years ago) i have been using a angle grinder because it is quicker for me,but i never used a balancer or even a nail set up like jd green uses(and jd does like most people and lawn service co's. do) which i think is a good thing. the thing is that if you don't balance the blade(s) "supposedly" you may experience vibration on the mower , which i never have felt. there is a mower blade sharpener/cleaner from ...magna-matic.. that is suppose to be the cats.....for sharpening and cleaning the grass and rust off the blade, but the price is (imo) so high that i dont see how a person can justify owning one.but many people on a different forum swear by them.
I have thought about using my angle grinder but would hate to take too much metal off a cutting edge so I don't do it that way. Do you use a metal grinding wheel of any certain grit? Coarse or fine?
its just a cheapie black and decker 4 1/2 " grinder with a black and decker wheel but no indication of coarseness(unless "type27" means anything) but by feeling it i'm saying med/fine....i'm sure you wont have a problem with your blades just practice on a old scrap piece of like steel and "finesse" it you'll be fine with it,:thumbsup:
Thanks...a B&D grinder cannot be any worse than my "Crapman" grinder....:laughing::laughing:
4 1/2 inch grinder is quick & easy... Just a light touch, will keep it sharp and in shape, don't get too carried away and burn a hot spot into the metal...
I have also used a file.
Balancing a blade is not going to be a big issue. If you have a blade that is in such bad shape that its out of balance ... YOU probably need a NEW BLADE...
There is going to be someone that will sell you anything they can convince you that you need...
If you really feel that a co$tly balancer is needed ... then you should get an even MORE co$tly Dynamic balancer...that will really spin it up and computer balance it.:biggrin:
If your blades are not clean and rust free enough, you might look at having them powder coated while you have them off to resharpen :laughing:...
Reasonable care when sharpening a wire brushing and a nail will work fine... :smile:KennyV
$ 1/2" angle grinder, balance check, back on the machine.
easy, peasy, lemon squezey:smile:
Pardon me for asking, but how can you use a Nail to balance a lawn mower blade when it doesn't achieve the center of rotation.
I bought one of those cheap balancers at the local hardware store and I guess it does ok.I had some rusty blades that I cleaned up with a wire wheel and then applied a coat of EZslide as a kinda experment. won't know how that goes till spring. russ
