PTmowerMech
- Apr 16, 2018
- 397
- 3,023
Briggs 128M02 0945 F1
Original Carb was very dirty, so I put a new one on it. It fires right up, usually first pull. But revs up and down. Sprayed soapy water around where the carb mounts, and nothing changes. Took the cover off and didn't find any cracks in the intake.
So I cleaned out the original carb, and still getting the same revving up and down.
The only thing different is the throttle/governor spring is different. The original one was rusted and broken. So I put one on that's a little different, but seemed to have about the same tension on it. It's a little longer so I had to slide it over where the original one hooked to (front of the engine on the front plate) and hook it below. I tried more & less tension, but it makes no difference. Less tension, slower idle, it doesn't rev as much. But still revs.
The plug is good. Compression is about 65 to 70 with fresh oil. New air filter.
Any suggestions?
Any suggestions?
