Universal oil
bckskin2
Some of my equipment uses 40:1 and some 50:1. My Stihl dealer suggested a "universal" oil. Yesterday my chainsaw had almost no power and was hard to keep running. I dumped the gas oil mix and got a fresh gallon of 87 octane and a fresh bottle of Stihl brand 50:1 in the silver bottle. Once I got the mix in the fuel line burned out it seemed to run OK. I hope that was the problem. I guess I will find out today. The mix was a couple of months old, but was 87 octane alcohol free.
Jerry
Some of my equipment uses 40:1 and some 50:1. My Stihl dealer suggested a "universal" oil. Yesterday my chainsaw had almost no power and was hard to keep running. I dumped the gas oil mix and got a fresh gallon of 87 octane and a fresh bottle of Stihl brand 50:1 in the silver bottle. Once I got the mix in the fuel line burned out it seemed to run OK. I hope that was the problem. I guess I will find out today. The mix was a couple of months old, but was 87 octane alcohol free. Jerry
I run 50:1 in everything.
Never had any problems.
Ams oil 100:1 in everything that is 2 cycle never had a problem. I even use it in my antique Artic Cat which called for 16:1.
Jerry
Where was your gas stored at? Stihl is now recommending 89 octane or higher but that is for the gas with the 10% and 15% ethanol content and keep using the Stihl HP Ultra mix.
50:1 is the norm, most run 40:1 to keep everything lubed better but I am using 44:1 now since my mixing cup states that.
2 cycle oil mix
Check This Out ......... ( Opti2-4 ) on the net , Problem solved !! Boobala :thumbsup:
