uneven cut on troybilt
Gerry Neese
Is is possible to have one blade rotating slower then the other. I have leveled the deck, replaced the blades and had three mower mechanics look at my bronco riding mower and no one has a solution why the left side cuts good and the right side just knocks the grass down with little cutting
What kind of shape is your idler pulley spring? A weak spring could cause the belt to slip a little
Hello & WELCOME to LMF...
I realize you have had others look at it...
But a very commonly overlooked problem is one blade mounted upside down... It happens a lot... :smile:KennyV
