greynold99
Ok! This past weekend I changed over the fuel line to bypass the metal fuel tube through the engine shroud and mounted it on the firewall. While I was at it, I changed the fuel pump as well. Aside from a slight bit of wear on the cam-driven pump-lever coming out the back of the old fuel pump, I couldn't see anything significantly wrong.
The only difference was that the fuel-line connections are now plastic/nylon instead of metal; and you have to use a split-ring tool to depress the internal locking retainer ring so the rubber O-ring seals on the plastic connection nipples aren't damaged when you insert them.
Other than that, pretty much a snap to install.
I ran the tractor a half-hour afterwards to check for any fuel leaks, not enough to verify that it has absolutely fixed the problem but the first thing I noticed was how fast it started up even with the additional length of fuel line. I mean there was almost no cranking before she started up. Plus it seemed like a smoother running condition - no noticeable additional power just more consistent power if that makes sense.
Soon as the rainy period is over here I'll be on it to test the heating/shut-off issue.
greynold99
greynold99
