Turns over won't start 102 hrs on it
3 things keep a gasoline engine from running - lack of fuel to air ratio, lack of spark, and lack of compression.
Right right...... I say 4. Air, fuel, spark (at the correct time) and compression.
Agree especially E-10, goes bad in 30 days. OP probably has water in the system or stale fuel. ????
What do you spray it with? I tried reusing a sprayer, and the fuel just leaked out in a hurry.
I use a simple plastic hand pump sprayer. Like cleaning windows with. Like a plant mister.
Taryl has them in his online store.
Rich folk use the below.
I have gone over to 2 stroke mix myself. Works in any two or four smoke engine. Way less flammable plus lubes every cylinder you spray it in. Cheaper than canned death types like brake cleaner too.
Even at today's ultra high gas prices, if you mix a gallon and some 2 stroke oil, will last you forever compared to canned death types. Can of brake cleaner is what $6.00 - $12.50 depending on brand?
They won't run on the brake cleaner I use. I'm not talking about trying to run it long term just long enough to see if it will start.
Use brake cleaner for, cleaning brake parts. Even then I use a garden hose and shop air. I want all that dust down the street before I dive into some pads.
there are different kinds of brake cleaner. Some are flammable, some not. I use Berryman's B12 carb cleaner or a little gasoline in one of those bottles. Which ever is handy and near by.
