shrpshooter99
I recently picked up a craftsman 6 speed 42inch deck, with an 18 hp Briggs motor in it. But the motor that was in it had been blown up by the owners son. He had a 14.5 hp OHV Briggs motor that he gave me with the mower proclaiming that it should work when put on. I did the motor swap got everything buttoned up, went to turn the key and all i got was a click. I talked to some others and they all pointed me towards the solenoid. I went down sears and picked a new one up and put it in, but it did the same thing. Thinking it was the starter i took the started out of my older white. The motor in the white it a 14.5 pressure lube motor, which runs great. I swapped the starters and the same thing happened. The only though i have is that it must be electrical, or maybe a bad battery, or bad ignition?
