Tuff Torq K57 Rebuild
Craftsman Garage
Hi guys, I have a Tuff Torq K57 from a Husqvarna YTH24K48 and was wondering what is involved to rebuild it? I just want it to be restored to the original speed, and I'm planning to resurface the pumps with sandpaper, but I was wondering if just resurfacing things would fix the transaxle groaning? What causes this? Also, what would be the best oil to use in this if I clean it all out? I'm hearing a lot of conflicting answers about this.
Cavitation...
You need at least a seal kit
1A646099151
or if center section and pump motor(s) are a repair kit.
1A646098420
When disassembly pay very attention to part placement. Better yet take a lot of pictures as you disassembly. Item 36 is the motor plate that can be installed 180 out. This will reverse the transaxle operating directions.
Craftsman Garage
Cavitation...
1A646099151
1A646098420
Thanks, Do you know which filter is better, the older paper or the newer mesh one?
