My wife bought this mower at a yard sale:
Troybilt 21" self propelled mower
AUTO CHOKE
Model: 12AV565Q711
Serial: 1E147K10613
Engine: Honda GCV160LAS3H
Of course, it won't start now, although she swears that it did when she bought it
) When you pull the rope, nothing happens. No sputter, no nothing. Sounded like it wasn't firing. I feel pretty sure that part of my problem is the carb and have decided to go ahead and get a new one. But before I do, I have some general questions I am hoping someone can help me with.
1. Spark plug - The one in it was a NGK-BPR6ES. I found some doc online that said to use a NGK-BPR6ES only for power washers, and to use a NGK-BPR5ES for everything else. Does anyone know the correct plug to use?
2. There are 2 long wires that attach to the top of the carb. One is hair thin, and the other is thicker. Does the handle that you pull back to start the mower regulate these? When I pull that handle back, nothing moves. I can see the cable moving back when I pull the handle back, but nothing on the carb moves.
3. I don't know what you call this other piece, I think it is something like govenor's arm. When the mower would finally start for a second, I used my hand and pushed that thing back and forth and that would keep the mower running very roughly for a little while, and once I stopped moving it the engine would just stop. What controls that, and is there something that might be wrong with it?
4. How do you get the red cover off? The only screws I see are for that black thing where the rope is at.
I'm no mechanic and am just starting out with this stuff. I have no problem tearing things apart, but have a heck of a time putting stuff back together so that it works
Thanks very much
AUTO CHOKE
Model: 12AV565Q711
Serial: 1E147K10613
Thanks very much
