Troy built Horse xp deck engagement cable
rocky4
Troy Built Horse 13CX79KT011 2014 Deck engagement cable broke between spring and mounting bracket. What is the easiest way to replace cable? Thanks for any help
There is no pto , direct belt driven
I like to start from the deck and fed the cable in backwards cause there is less for it to get stuck on that way
No real secret to it just make sure the PTO lever is in the off position.
rocky4
OK thanks. on this one there is no pto just an engagement lever.
he Pulley is the PTO ( Power Take Off )and the lever you pull - push - twist to make the blades spin is the PTO lever.
Some times called the "Deck Engagement Lever" to make the mower sound more soficticated than it is .
