I have a 15 year old walk behind Troy Built with twin blades (33") cut.
from time to time when using the machine, the blades will stop turning.
it can happen every few minutes or once or twice per mow.
Has anyone else had this issue? is there an adjustment that a novice can make?
It's getting very frustrating to mow, when you have the re-engage the blade every few minutes....
thank you
thank you
