YardMonkey
Not big one, small 4 cycle one.
Changed the fuel line and the other line that runs from the carb to the gas tank.
I pump the primer bulb and no gas moves thru the lines.
What did I do wrong...I put the plastic hoses on the carb, ran the lines through the little holes in the gas tank and up the little black filter on the end of the hoses...
