Thanks for your help, While looking at it today, the throttle assembly was messed up and the item is no longer carried. It will move at the handle but at the carb control it doesn't open or shut off the engine so the linkage is probably ok. the cable could be broken inside, I will check today. Again thanks
Bama49
