I have a TroyBilt Pony that was Purchased in 2011. It was running great and the engine still is, but noticed that it started to slow down and then stop moving while mowing. The issue would start after the mower has been running for 15 mins or so, and if I press the pedal and release it would "take off" again and I could mow for a little while. I notice that over time it was getting worse to the point where pressing and releasing the pedal did nothing, but there is no hesitation in the engine at all. Also I have a few extra pounds on me, and if someone who is lighter gets on the issue doesn't seem to show as much.
So far we have replaced the belts, and have also taken the transmission apart, checked the gears and re-greased as it was a little dry. The issue after this has gotten better, but it's still there.
