Tiger Small Engine
If the engine runs good at all RPMs except WOT with blades on, then the flywheel key is fine.Yes if you push throttle a the way up it activates the choke. However I have the engine cover off so I can see the throttle move and the choke is definitely not engaged. Even at 7/8 throttle and running fine if I engage the blades it instantly bogs down. I am going to check the flywheel key to see if it has moved. Also going to recheck the valve lash as the compression was 140.
