Troy bilt leaf blowet
Edrdking
I have a Troy bilt 4 cycle leaf blower. The thing starts good and idles good. Once I press the trigger for some power it dies. If I let off it starts right up again. Any one have any suggestions????
I think I solved my problem. Cleaned the carb and put it back together and it seems to be working. Wont buy another Troy bilt the power that it produces has never been that great. Stick with echo or Sthil others not worth it.
I've got the Troy split boom tool. Probably the same cheap Chinese engine. But mine runs great. I've found that the valves are sensitive and need to be adjusted regularly. The specs are in the owners manual.
