Troy Bilt Bronco with Auto Transmission
mag1951
When I put the mower in neutral, and try to push it or pull it, it acts as if it was still in gear. This is when the engine is off. When I start the mower, and put it in forward gear or reverse gear, it does what it is supposed to do. Any idea what might be wrong? Mower is about a year old and it just started doing this.
You have release the bypass valve to move it around. Look for a lever or rod on the back of the tractor.
MowLife
Are you sure is a “Auto”? Most Troy-bilt are vari drive...shift on the go type. Anyway check to see if brake is hanging up.... very common on these models especially if you use the parking brake often.
panabiker
I too think it's more likely a brake problem and needs cleaning and/or readjustment. Take a look at the brake disc. The dirt and debris can accumulate around or behind the disc and cause it to jam.
