Hello! New member looking for help with my Briggs & Stratton no. 125K02 0243 E1
Carb was leaking and mower would NOT start... so I cleaned it using paper clip and safety pin and carb cleaner. I also replaced bowl washer, seal and the gasket. It has new spark plug and air filter.
It will now turn over when I push the primer (many times) but then stops.
It seems to stop after burning the fuel from priming.
I did not replace the needle as it was not sticking and seemed to be functioning properly. Also, I feel sure the fuel is getting in the carb as it was leaking until I tightened the bowl nut a bit more.
Am I missing something?
Thanks
Thanks
