primerbulb120
- Nov 3, 2014
- 1,315
You can get the screwdriver on Amazon.
And you have your gaskets switched around.
And on the engine side of the carburetor, that little hole beside the main carburetor bore MUST be lined up with the corresponding hole in the gasket. If the hole is blocked, your fuel pump will not operate and the engine will act weird.
