Repairs trouble shooting
BlazNT
In terms of cars, this is OBD1, not OBD2 so no software at all.
mcdonell
I found a free PDF file on-line for my Kawasaki motor manual that I downloaded for reference. It even has a part number. I found the manual doing a google search for my engine model. You might want to try that.
The codes are in the engine manual which is free download from Koher .
There are a few different systems used so you will need to input your actual engine numbers to get the right manual.
Luffydog
Has your engine been black smoking any at all
Luffydog
Thinking it might be the throttle position sensor. Ill have to find the codes when I get back to work. I take it oil is at operation level and air filter is clean.
