Just got an old hydro175 in pretty good shape. Started right up, bowed strong and cut nice. Once. Second time, at first it made no sound when I turned the key. nothing. after trying a few times, it started right up again. No hesitation in cranking or firing. Then it threw a worn deck belt, and now I get nothing when I turn the key. Headlights come on, and if I move the blade engage switch, I can hear it clicking, but other than that , nothing. Any suggestions for how I might try to track this down? I tried (maybe not well) to bypass the ignition and short the solenoid/starter - only got the tiniest of spark, and still no crank. It has the Kawasaki engine, if that helps. Really appreciate any suggestions!
