Trobilt riding mower starter
depends on which briggs engine. some you can remove the cover over the starter drive and then remove the two bolts that hold it to the engine. others require that you remove the flywheel to get to the bolts. just make sure you hold the inner nut that the wire goes to so you don't twist the wiring inside.
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
