transmission noise
simonh1952
when I release brake pedal transmission works forward and backwards but transmission makes noise I notice drive belt is worn and cracked could this be the problem
If there are any burnt spots or chunks missing can make things vibrate and rattle. Also check any idler pulleys for rough turning indicating a bad bearing.
Noise ?
So it pays the star spangled bannar thus you stand to attention and salute then while doing this the engine stops ?:laughing:
bangs
Crashes
Squeals
Moans
Grown
farts
simonh1952
thanks will replace belt and let you know what happens
