towing
sss
i have a pin hitch on my rideing mower but i need a ball does anyone know how to fit one?
reynoldston
No big deal. I don't know your ball stud size but if it is too big for pin hitch hole you can either drill it out or take a rat tail file and enlarge the hole with the file. I had to bolt a extension on one of my mowers. That wasn't too bad ether. I took a flat steel bar and bolted it to the hitch hole and the ball on the other end. This would also work if you didn't want to enlarge the pin hole.
sss
thanks for the reply i will try it:smile:
