SweeperForce
- May 5, 2013
- 2
- 2
Hello,
I have a 10685 walk behind SP mower. I usually prime it three times like it says and pull. It take anywhere from 15 to 25 pulls to get it started. It doesn't matter if the engine is hot or cold. I thought I was flooding it by priming too much so I tried priming it once and then again with out priming at all. Seemed to make no difference. I read on here and other sites my problem could be bowl related. Do I just loosen the bolt under the bowl to remove it clean it out and reinstall it. Or is there more to my problem than that.
Thanks,
Tom
Thanks,
Tom
