Torque Values PLEASE..
Speedracer2023
Hello all. I have a 2011 X324 with the 48 inch mower deck with the rotatable wheels. I have taken it down for winter maintenance and came across a few items that needed to be addressed on the mower deck. I have the JD service manual and it is of no help (unless I am looking in the wrong area). I am looking for the torque specs for the following items: The nut/bolt specs for the bolt that goes through the 2 sheaves on the mower deck drive arm (the big black piece of metal with the bearings in it); the bolt/nut specs for the bolt that attaches the mower deck drive arm thru the U shaped bracket and then attaches to the underside of the mower deck and the nut specs for the two idler sheaves. I try to do things right the first time so IF you have this info or can direct me to where I can find it would be much appreciated. Thanks to all for any help provided. Happy Holidays..
