Torque spec
Need torque spec for Briggs 190 cc Lhead to Toro recycler aluminum deck. I've looked everywhere and can't seem to find it. I am getting some noise on a recent rebuild and it sounds like it is coming from the deck or blade. Blade is like 60 ft lbs so I doubt that is it, but the deck bolt torque I found on line and used seemed light, however don't want to strip out the engine case. Sounds like the tip of a blade hitting something but there is nothing to hit unless the engine is moving around on the deck. Have set the morning aside tomorrow to work on it and replace the struts on a 2004 sable wagon. Hate to spend either until midnight tonight or part of tomorrow trying to find the proper spec on the engine to deck torque. Typical 3 bolt setup as I recall.
Took me 15 seconds to find this.....
Hello Sgkent,
Can you narrow down your analysis of piston slap.
Is this the wrist pin or connecting rod?
Thanks,
Doug
