sdkeightley
I recently changed the oil filter on my ride on mower, after replacing the filter and oil I checked for leaks, ran the engine and re-checked, no leaks.
After using the mower the yesterday I noticed a large amount of oil seeping from a nut at the base of the engine to the rear of the oil filter.
There are no leaks from the filter or drain plug, but there is oil on the spark plug. Not sure but the oil seems to start seeping when I engage the blades.
